Hey, I've got a bit of a problem. I've recently built a new computer (about a month ago) and it has worked fine... until now. Basically, I woke up this morning and pressed the power button and nothing is happening. The fans don't turn on (they are attached directly to PSU btw), PSU doesnt turn on, nothing turns on, however there is a green LED on the mobo which turns on as normal. I've checked all cables and they are working fine... no idea what to do now.
Before you ask, I DID jump start the PSU, and it DOES turn on that way (and all the fans go on etc), but it just doesn't work when I plug it into the motherboard and press the case power button.
Thoughts?
Thoughts?
