TechieSooner
- Nov 7, 2007
Suggestions on this?
Basically, if one goes down, the other needs to come up. I don't care about load balancing or anything like that (though if I can do it, wouldn't be that bad of deal), mainly just wanting redundancy.
So, I'm planning on two different technologies (Fiber, Cable, T1, etc) with two different ISPs.
The biggest issue I see is incoming IP addresses.
IE, I have a web server on 210.210.210.210, another on 210.210.210.211, and Exchange on 210.210.210.212 (Bogus IPs). Going to web1.domain.com resolves to 210, web2.domain.com resolves to web2.domain.com, exchange.domain.com resolves to 212.
You get the idea. Let's say all those IPs are on a Cable connection. The cable connection goes down, so I want to use the Fiber connection. For web browsing, tweaking the router config with the new IPs, it works instantly. But those IPs on that Cable connection are now dead. They aren't getting routed to the Fiber IPs.
What's the solution to that, other than waiting hours for DNS changes to propagate?
I think it would require cooperation from both ISPs to get some sort of failover system setup. Which getting competitors to compete, probably is going to be a bigger pain than it is worth!
