Failed to upload units
Forthy
Whilst doing something completely irrelevant I ended up looking in the FAHlog.txt on my lappy, and noticed that every time I boot for the last couple of days it's been trying to upload two WU's, and failing.
I've just stopped the process, and run a "-send all" and it successfully uploaded both units first time with no issues.
My question is: Would they have eventually gone on their own anyway, or could this be an issue? I ask because it's total fluke that I spotted these when I did, and need to know whether to keep a closer eye and 'force' and upload once in a while?
TIA :)
its possible they would have sent on their own, but i'd suggest watch it the next few days to see if it actually is a fluke, or something wrong in your config.
When I've had uploads not working right, I've traced the issue back to my router. If QoS was enabled, I found they'd croak after 30 minutes or so, once disabled, the connection didn't drop.
I would keep the process folding, and it will automagically try again every few hours to clear the queue. You can also run it again (just say ok to the process conflict warnings) with the -send all tag and it won't disrupt your folding work.
Thanks for the info guys, I'll keep an eye on it and update in a few days :)
