Failed Folding on 4870 Please Help
Good Afternoon [H]orde,
Im having an issue. I just recently got a Sapphire 4870 from a friend to use in my machine. Im now trying to fold with the GPU and it is not working. I am using FAH GPU Tacker V2 version 3.52. Configuration on GPU0 is Enabled Enable GPU3 is unchecked. Tried leaving force at non and tried ATI R700. When I start the GPU0 I get the following
[17:02:51] Starting GPU 0.
[17:02:51] Started new WU on GPU 0.
[17:03:12] GPU 0 failed to complete a project 5736 WU (UNSTABLE_MACHI
[17:03:12] Deleted WU on GPU 0.
[17:03:12] Starting GPU 0.
And it continues on again and again for 10 times and then it shuts it off saying that its gone through too many fails. Please Help. Would like to fold on the GPU
OC on card?
Also what CPU do you have? It might be better to fold with it.
I will let someone who is or has folded on an ATI card answer then.... I'm just not up to date on current GPU folding.
given that its a 4870 and you are limited to the old piece of junk gpu2 WU's you are better off not folding on the card. it hurts smp performance to much to make the excess power usage worth it.
