Failed DVD-ROM Flash - Still Works
tuffgong
I have a Samsung TS-H352A DVD-ROM Drive. Stock firmware was TS03 and the latest is TS05. I used Samsung's utility to upgrade and a "download failed" message popped up. The progress bar reached 100% and the drive is working perfectly.
What the heck?
I tried reflashing to older firmware same exact thing happened. I've got warranty on the drive anyway. could a loose cable caue the firmware fail?
so does the drive run on new firmware right now? check it with nero drive information or smoething that will read drives firware ver. Did you try upgrading firmware on different computer? you do that before RMAing the drive..
The firmware is being read properly///i just dont get it. drive is working fine also.
