I had a drive do this once, it was fine on one system and broken on another.
Do you have access to another computer??? Your drive may need a firmware update in order to function with your new board.
You,d need to know the brand, then go to their website.......catch 22 though because you need a functional computer to load the new firmware.
Or borrow something from a friend and see if you can load the OS then update the firmware on your new drive.......or just RMA it......sometimes bad luck is just bad luck.
another idea, change the cables....might be a bad cable, and place the drive in another port location.
The only reason I recommended that you have only the HDD and CD plugged in is, the fewer variables in troubleshooting the better.
