Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
[H]ard|DCer of the Month - February 2007/January 2
Right click inside the FAHmonitors white screen to bring up the "Add a new client" box.
Left click in the "Add a new client" box to open it.
In the top section enter the name you want to use to monitor the box.
In the bottom section enter the path to the folding folder.
You can use the "..." button to navigate to th folding folder if you dont know the path.
Click Ok and you should start monitoring that client.
Edit, Its normally the first two steps that fox you when you first start with FAHmon as theirs no obvious "Add client" button in any of the menus.
