Fahmon glitch ?
Hgradio
I am old and too late to learn how to post logs etc (and badges). You can check this out for yourself in fahmon. To elaborate, I was sitting here lookin at the GPU 1 finished attempting to get work unit for the ( insert number here) time. Then for the heck of it I clicked on some of the other clients to see what the WU numbers were. That is when I noticed that one or more of the (finished) said downloaded 2hrs 15min ago. I looked thru the logs and it seems to me that a WU is getting assigned but not downloaded ? Anyway, one of you guru's want to check similar things in you fahmon perhaps. After watching this for a while, it seems that although the Wu was recieved, the timer keeps running until a new WU is started.
What you are seeing is correct.
Fahmon bases it data on the F@H information.
If a work unit has not started yet, is assumes you are still running the older one.
This is normal behavior for that program.
