EvilAlchemist
- Jan 11, 2008
FahMon 2.3.3 Released
FahMon 2.3.3 is now available for download here: http://fahmon.net/download.html
What's new in this release:
* The client list view has been made much more configurable and additional columns can be added with a right click on the column title.
* You can now completely hide the WU Info panel on the right hand side of the main FahMon window.
* Clients can now be managed from the main menu instead of a right click menu in the clients list.
* Clients can now be manually disabled if you don't want FahMon to monitor them.
* Paused clients can now be detected and shouldn't register as *hung*.
* A number of debilitating bugs that affected GPU monitoring have been fixed.
* FahMon on Windows now follows MS guidelines for storage of settings. This means no more problems with UAC on Vista when downloading project updates.
v2.3.3 (01/11/08)
General
* Added new cores support.
* Made "Last 3 Frames" the default PPD/ETA calculation method.
* Added multiple new data columns.
* Made client management more intuitive by adding a "Clients" menu.
* Made main window menus more intuitive.
* Added ability to remove the "WU Info" panel from view.
* Updated queue structure to qd FR 069
* Add ability to select custom web output templates.
* Altered About Dialog text.
* Added custom variables to web output templates.
* Fixed GPUv2 always reporting PPD as "inaccurate."
* Updated folding support forum link in "Web" menu (thanks to Mark Gerber).
* Fixed div by zero error that affected GPU2 clients (thanks to John
Daiker).
* Fixed quick refresh crash bug (thanks to John Daiker).
* Fixed file manager bug with paths containing spaces (thanks to John
Daiker).
* Fixed team number and username refresh issue (thanks to John Daiker).
* Changed client list style and removed "zebra" background colour scheme.
* Issue time no longer used as download time.
* Added ability to disable clients.
* Improved sorting algorithm.
* Added client pause detection.
* Added support for truncating usernames in the web output.
Windows
* Fixed cosmetic issue with work/current.xyz using / instead of \.
* Migrated configuration folder to %APPDATA% to improve behaviour in Vista.
* Updated installer to add entry to add/remove programs.
* Fixed some minor installer issues.
* Now built against wxWidgets 2.8.9.
Linux
* Fixed an issue with latest GCC and inline functions (thanks to KB3LWJ).
* Fixed compiler warnings about deprecated conversions (thanks to John
Daiker).
* Added configure test to check for ANSI wxWidgets and warn if found.
v2.3.3 (01/11/08)
General
Daiker).
Daiker).
Windows
Linux
Daiker).
