Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You can set the time on your machine to GMT. Thats the time the the log uses. I have not tried yet but I'll bet if you tell your machine that it is on GMT thy will match. I'll try it right now and get back.
Hey it worked. I set the time zone to United Kingdom and then set the current local time and now the FAH timestamp is on local time.
