FahCore_65 vs. FahCore_78
Carnival Forces
how come v4 still uses FahCore_65.exe instead of the FahCore_78.exe ?
both are in my \Program Files\Folding@Home folder, but it decides to use the FahCore_65.exe all the time; i tried moving the FahCore_65.exe folder away, to another folder (on the same drive), and it still used it; so then i moved it onto another partition...and it still used it
:confused:
Both cores are in use depending on what WU gets downloaded. Gromacs uses 78 and tinkers use 65. What you see is normal, in fact as those cores are updated you will get new ones.
Not to worry, it's all good. :D
BillR
No need, your doing just fine :D
Fold on
BillR
There are four cores you could have.
FahCore_65.exe, FahCore_78.exe, FahCore_c9.exe & FahCore_ca.exe.
DGromacs and G@H use the other two.
Luck......... :D
Luck......... :D
thanks for the additional info. :)
I also have a fahcore_79.exe in one of my folders that was downloaded on the 28th of july.
T-3
