FAH shutdown
ReconSniper
I keep getting this all of a sudden.
[23:04:36] Project: 5801 (Run 4, Clone 521, Gen 0)
[23:04:36]
[23:04:36] Assembly optimizations on if available.
[23:04:36] Entering M.D.
[23:04:42] Will resume from checkpoint file
[23:04:42] Working on p5801_supervillin_e1
[23:04:43] Client config found, loading data.
[23:04:43] Resuming from checkpoint
[23:04:43] Verified work/wudata_03.log
[23:04:43] Verified work/wudata_03.edr
[23:04:43] Verified work/wudata_03.trr
[23:04:43] Verified work/wudata_03.xtc
[23:04:43] Starting GUI Server
[23:04:53] mdrun_gpu returned
[23:04:53] NANs detected on GPU
[23:04:53]
[23:04:53] Folding@home Core Shutdown: INTERRUPTED
[23:04:56] CoreStatus = 66 (102)
[23:04:56] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
The 5801 GPU2 work unit is known as a bad unit....hopefully they will be out of the system soon. Restarting the client should get you a new work unit, but worst case scenario, you can go into the FAH data files folder for the GPU2 client and manually delete the work data.
