F6 or 7 bios DS3 for higher overclock
whiskey29
Has any one tried F6 bios DS3 makes the overclockability of 6300/6400 indeed higher ?
i have tried F6 without gaining any higher fsb . i cant find stability above 460 at this point. even though i can boot up to 490
I've used F1 (I think thats what it came with, maybe F2), F3, F4, F6, & now F7. I just flashed to it last night so I have limited results so far....
I don't think it will help you reach a higher CPU overclock, if you were CPU limited.
I do think the new F7 bios can help you if you were FSB limited before. Also it removes the problem with lowering the multipliers on the e6600/6700. Now I can boot at all kinds of combinations 8x400+, 7x450+, etc to name just a few.
So if you have an e6600 and are limited to like a 3.2Ghz overclock (355 x 9), before you probably couldn't use 400x8 b/c it just wouldn't boot, where now with the F7 bios you can use that optimal FSB setting. (400 x 8)
edit: read the Anandtech article: http://www.anandtech.com/mb/showdoc.aspx?i=2854&p=2
Though I don't think they went in depth enough. I thought they should have tried it with a few different chips, that had reached different FSB walls.
Ok Guys, I tried it as well although haven't do extensive testing.
On F5, anything above 484 is no post and system reset it self back to default.
Flashed to F6, I managed to boot into windows at 490, although it's not stable,
Orthos ran for a few minutes and gave error on Small FFT, then I increased CPU voltage
the it ran a bit longer before system lockup.
i flashed to F7 and achieved memtest stable at 480 fsb , i will try for higher today
hugs
Jen
I've been doing some various tests. And I've been able to boot at all of the FSB's that I've tried so far, granted I have to lower multiplier to reach the higher ones, but before it wouldn't work at all.
F7 removes the FSB hole that was around 360'ish to 400 for many e6600/6700 owners.
Its definitely the best BIOS so far for the DS3.
