F4-3200C15D-16GVK with 2700x - AIDA64 result anyone ?
Discussion in 'AMD Processors' started by BBen1979, Nov 15, 2018.
  1. BBen1979
    BBen1979 n00b
    8
    Jan 10, 2013
    Hi Guys,
    Looking for some AIDA64 result for this memory kit with a 2700x .
    Can anyone help, I spent a hour looking all over on the net ;)
    Thanks
  2. LigTasm
    LigTasm [H]ardness Supreme
    4,912
    Jul 29, 2011
    I used to have this kit but I don't any more, wish I could help. I have the Gskill 3200 C14 kit now along with a Corsair 3200 C15 and Patriot 3000 C14.
  3. BBen1979
    BBen1979 n00b
    8
    Jan 10, 2013
    With a 2700x ? If so would you mind providing the AIDA64 for those with the specific model of the memory kit.
    I'm interested in knowing if there a big difference between C15 and C14 kit.
  4. LigTasm
    4,912
    Jul 29, 2011
    I have a 2600X and an 1800X, the 2600X should be pretty much identical in terms of memory performance. But I can do them up and post them anyways.
  5. BBen1979
    BBen1979 n00b
    8
    Jan 10, 2013
    Yes should be about the same. Thanks in advance!
    370 or 470 mb ?
  6. LigTasm
    4,912
    Jul 29, 2011
    Sorry all my boards are 350/370 my X470-i Strix died. I will start working on it in a few but I probably won't be done until tomorrow.
  7. LigTasm
    4,912
    Jul 29, 2011
    My apologies, my Corsair kit was actually C16, I haven't looked at it in a long time and I forgot.
    These are the kits I ran on the 2600X today with Gigabyte X370 Gaming K7:
    Corsair 2x8 CMK16GX4M2Z3200C16 16-18-18-36
    GSkill 2x8 F4-3200C14D-16GFX 14-14-14-34
    Patriot 4x4 PV48G300C6K 16-18-18-36
    I'm out of time for right now but tomorrow I will run them all on the 1800X just for fun. Looks like not much difference (in this program anyways) between a 3200C16 and 3200C14.
    BBen1979 likes this.
  8. BBen1979
    BBen1979 n00b
    8
    Jan 10, 2013
    Thanks a lot for this!
    I was expecting a bigger gap between those 2 set Corsair 2x8 CMK16GX4M2Z3200C16 16-18-18-36 & GSkill 2x8 F4-3200C14D-16GFX 14-14-14-34.
    Good to know, F4-3200C15D-16GVK should be right between those 2 results. Anyone know if there would be a bigger gap with a X470 motherboard? or about the same result.
  9. LigTasm
    4,912
    Jul 29, 2011
    Supposedly the 400 series has slightly improved memory performance but I think they would all move up about equally. The 200mhz jump is definitely worth the price though because I noticed some decent gains in games especially in minimums.
    Maybe someone else can chime in.
    EDIT: just for fun I ran them on my 1800X machine (bear in mind this is a B350 board which I actually feel is more responsive). Also of note is the L1-L2 cache is significantly faster on the 1800X, I do not know if the 2700X would have the same advantage over the 6-core.
    2133C15
    3000C16
    3200C16
    3200C14
  10. sirmonkey1985
    sirmonkey1985 [H]ard|DCer of the Month - July 2010
    20,912
    Sep 13, 2008
    the only risk with C15 is that it can have either hynix or samsung B modules.. C14 is guaranteed samsung C16 is hynix.
    but if you're going zen+ they have way better memory compatibility than the first gen zen processors. can even run most C16 3200 hynix at their rated speed unlike on first gen.
