Lone_Bullet.be
- Jul 26, 2005
Sorry for posting this 2ce but its colling and OC relatred as well as SSF related...
I made the stupid mistake of placing a 8800GTS is a Antec Fusion.
It works like a charm exept that it makes my casetemps go around 40-45 °C on Idle...
So i though, i'll buy 2 better fans ( Skythe S-Flex 1200RPM ) for hopefully a bit better silence/airstream ratio... and i'll let one being throttled by the Abit's EQ fan control ( connected to the Sysfan connector, not the AUX, from what I understand the AUX fanconnectors ain't controlable.) But it doesn't throttle...iut just goes on 100% or 0%
Settings:
target temp : 40°C
tollerance: 5°C
start control: 100%
stop control: 70%
what am i doing wrong? and can anyone explain the start and stopcontrol a bit better?
English ain't my native language and i don't get the full explaination from the mobo manual.
Also, could anyone explain thet the PWM fan is on the Abit EQ settings? GPU fan ?
Also:
CPU: E4300 @ 2.7Ghz ( can't get the mobo stable on 333 FSB for 3Ghz :s ) @ ~40-47°C
GPU: 8800GTS 320 @ stock in 1st 2 slots @ ......well HOT for such a small case !
RAM: Corsair XMS2 800Mhz 5-5-5-12 2x1Gb
CASE FAN: Skythe S-Flex 1200RPM 1@ SYSFAN, 1 @ AUXFAN
CPU FAN: Nexus skite ( looks like copper Intel HS with 92mm Nexus fan )
ty
Settings:
target temp : 40°C
tollerance: 5°C
start control: 100%
stop control: 70%
Also:
ty
