Send a PM to harlam357 or post a message on the HFM Google group with your issue and he'll look into it for you.I would like to try HFM.net but I cannot it to start on my system.
Running XP64 and when I try to start it, it just throws an Application error (0xc0000135).
Bummer man, that is very odd. Works awesome here on XP64. Sorry.I would like to try HFM.net but I cannot it to start on my system.
Yes, but that's not the problem. On my display resolutions even when all columns are enabled, I still have room to spare. It is the rows that are too close together. I think the only thing that will make it easier to read with the resolutions I use is a larger font, or simply more spacing between rows. I have never seen a F@H monitoring program with this level of data density, and have been using monitoring apps since the days of the venerable G@H Spy.Apollo - You are aware you can hide certain columns you don't want/need shown and you can also move the columns around to better display want you want, correct?
