F@H under Linux
Elf_Boy
Hi guys put together my system to play with and learn linux.
Might as well run F@H on it. I am not seeing a GPU client, is there one? Or is it just cpu only? Is that worth doing on an AMD Penom x4?
There's no native gpu client for linux at this time.
A phenom x4 should be well worth running the linux SMP client on.
If you want to really dive in head first, there are ways to run the windows gpu client under linux, and you can certainly learn a bit doing it.
Google around, there's a guide on FoldingForum.
