F@H Question
erehwon6811
When I set it up, I told it not to run as a service. I have turn it on at startup. I use EMIII and there is a start F@H on startup option. That doesn't appear to work. If I change it to a service, will it run on startup? And, if so, how do I change this?
run 'fah502-console.exe -configonly' (for version 5.02. replace the filename with whatever the exe is - just not the core) then (optional) go into regedit->HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\FAHwhatever then change "ImagePath" to include -forceasm on the end. it makes it use SSE extensions on a WU if it exits uncleanly. this is usually not necessary, but when running as a service it interprets any shutdown/stopping of the service in any way as an unclean exit. so it can help.
then go into service manager (Start->Programs->Administrative Tools->Services) an find the FAH service. start it. now you're done!
