Launched as a service.
Entered C:\F@H to do work.
[12:22:36] - Ask before connecting: No
[12:22:36] - User name: Codegen (Team 33)
[12:22:36] - User ID: 2C238BFD56848A4F
[12:22:36] - Machine ID: 1
[12:22:36]
[12:22:37] Loaded queue successfully.
[12:22:37] + Benchmarking ...
[12:22:39]
[12:22:39] + Processing work unit
[12:22:39] Core required: FahCore_65.exe
[12:22:39] Core found.
[12:22:39] Working on Unit 01 [September 10 12:22:39]
[12:22:39] + Working ...
[12:22:41] Folding@Home Client Core Version 2.53 (June 29, 2004)
[12:22:41]
[12:22:41] Proj: work/wudata_01
[12:22:42] Done: 22786 -> 142985 (decompressed 627.5 percent)
[12:22:42] nsteps: 5000000 dt: 2.000000 dt_dump: 250.000000 temperature: 355.000000
[12:22:42] xyzfile:
[12:22:42] " 393 p1112_L939_K12M_nat_min1_355K
[12:22:42] 1 N -40.660646 101.305178 95.3..."
[12:22:42] keyfile:
[12:22:42] "parameters ./proj1112.prm
[12:22:42] NOVERSION
[12:22:42] ARCHIVE
[12:22:42]
[12:22:42] cutoff 16.0
[12:22:42] taper 12..."
[12:22:42]
[12:22:42] - Couldn't get size info for dyn file: work/wudata_01.dyn
[12:22:42] Starting from initial work packet
[12:22:42]
[12:22:42] Protein: p1112_L939_K12M_nat_min1_355K
[12:22:42] - Run: 143 (Clone 77, Gen 1)
[12:22:42] - Frames Completed: 0, Remaining: 400
[12:22:42] - Dynamic steps required: 5000000
[12:22:42]
[12:22:42] Writing local files:
[12:22:42]
[12:22:42] parameters work/wudata_01.prm
[12:22:42] - Writing "work/wudata_01.key": (overwrite) successful.
[12:22:44] - Writing "work/wudata_01.xyz": (overwrite) successful.
[12:22:44] - Writing "work/wudata_01.prm": (overwrite) successful.
[12:22:46] - Writing "work/wudata_01.key": (append) successful.
[12:22:46]
[12:22:46] PROJECT="work/wudata_01", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=355.00
[12:22:46] TINKER: Software Tools for Molecular Design
[12:22:46] Version 3.8 October 2000
[12:22:46] Copyright (c) Jay William Ponder 1990-2000
[12:22:46] portions Copyright (c) Michael Shirts 2001
[12:22:46] portions Copyright (c) Vijay S Pande 2001
[12:30:36] Received unknown signal from OS. Ignoring...Received unknown signal from OS. Ignoring...Finished a frame (1)
[13:31:01] Finished a frame (2)
[14:28:44] Finished a frame (3)
[14:30:05] Received unknown signal from OS. Ignoring...Received unknown signal from OS. Ignoring...
[14:30:35] Folding@home Core Shutdown: INTERRUPTED
[14:30:39] CoreStatus = 66 (102)
[14:30:39] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
--- Opening Log file [September 10 14:54:12]
# Windows Console Edition #####################################################
Folding@Home Client Version 5.02
[url]http://folding.stanford.edu[/url]
Launch directory: C:\F@H
Service: C:\F@H\FAH500-Console.exe
Arguments: -svcstart
[14:54:12] - Ask before connecting: No
[14:54:12] - User name: Codegen (Team 33)
[14:54:12] - User ID: 2C238BFD56848A4F
[14:54:12] - Machine ID: 1
[14:54:12]
[14:54:12] Loaded queue successfully.
[14:54:12] + Benchmarking ...
[14:54:15]
[14:54:15] + Processing work unit
[14:54:15] Core required: FahCore_65.exe
[14:54:15] Core found.
[14:54:15] Working on Unit 01 [September 10 14:54:15]
[14:54:15] + Working ...
[14:54:17] Folding@Home Client Core Version 2.53 (June 29, 2004)
[14:54:17]
[14:54:17] Proj: work/wudata_01
[14:54:18] Done: 22786 -> 142985 (decompressed 627.5 percent)
[14:54:18] nsteps: 5000000 dt: 2.000000 dt_dump: 250.000000 temperature: 355.000000
[14:54:18] xyzfile:
[14:54:18] " 393 p1112_L939_K12M_nat_min1_355K
[14:54:18] 1 N -40.660646 101.305178 95.3..."
[14:54:18] keyfile:
[14:54:18] "parameters ./proj1112.prm
[14:54:18] NOVERSION
[14:54:18] ARCHIVE
[14:54:18]
[14:54:18] cutoff 16.0
[14:54:18] taper 12..."
[14:54:18]
[14:54:18] Hashes matched on file work/wudata_01.dyn
[14:54:18] Header on frame 2 differs from expected header
[14:54:18] Got: 8F0458-1004D-4319946A-3E30A873: 0002
[14:54:18] Expected: 8F0458-1004D-4319946A-3E30A873: 0001
[14:54:18] min1_355K
[14:54:18] - Run: 143 (Clone 77, GenProtein: p1112_L939_K12M_nat_min1_355K
[14:54:18] - Run: 143 (Clone 77, Gen 1)
[14:54:18] - Frames Writing local files:
[14:54:18]
[14:54:18] parameters work/wudata_01.prm
[14:54:18] - Writing "work/wudata_01.key": (overwrite) work/wudata_01.prm
[14:54:18] - Writing "work/wudata_01.key": (overwrite) successful.
[14:54:20] - Writing "work/wudata_01.xyz": (overwrite) successful.
[14:54:21] - Writing "work/wudata_01.prm": (overwrite).
[14:54:22]
[14:54:22] PROJECT="work/wudata_01", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=355.00
[14:54:22] a_01", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=355.00
[14:54:24] 2000
[14:54:24] Copyright (c) Jay William Ponder 1990-2000
[14:54:24] portions Copyright (c) Michael Shirts 2001
[14:54:24] portions Copyright (c) Vijay S Pande 2001
[14:54:24] Michael Shirts 2001
[14:55:10] Received unknown signal from OS. Ignoring...Received unknown signal from OS. Ignoring...Finished a frame (1)
[15:59:15] Finished a frame (2)
[16:21:41] Finished a frame (3)
[16:42:34] Finished a frame (4)
[17:03:25] Finished a frame (5)
delete everything FAH related on your computer.Codegen said:^
English?
low, i believe.Codegen said:I'm not sure why I renamed it to 500 :S.
It seems to be ok, now. Although, it is a Gromacs this time.
BTW, which is the higher priority, low or idle?
w00tage!Mayhem33 said:
