Eva_Unit_0
- Jun 1, 2005
I'm currently running the 81.85 drivers, and SLI seems to be *somewhat* functional, but not entirely in FEAR. By default it uses SFR, which for the most part seems to work, but whenever certain types of things are in the scene (like water, for example) the bar just sits at the bottom of the screen and the load balancing obviously isn't working correctly. And it's ironic because it goes haywire right at the times when you'd think it would benefit from SLI the most. Has anyone else seen this behavior with FEAR, or found a way to circumvent it?
On a side note, the first time after I installed the 1.01 patch it ran in AFR mode for some reason (which appeared to work better) but now it always runs in SFR mode again, even if I create a custom profile for FEAR and manually select AFR mode with coolbits.
Anyone have experiences with SLI (6800U's or otherwise) in FEAR?
