Please run F.E.A.R. at 1280X1024 with NO AA with Trilinear Filtering, all settings on absolute maximum except for NO soft shadows. Given suggestions from other members, this seems to be the best medium for a test bed that everyone can contribute to. This will give us a comparitive benchmark rather than everyone posting up random settings etc. Along with the scores we need at least some basic system specs ex:
A64 X000+ @ XGhz
Video Card @ ***/**** speed
#GB Memory @ X Speed...
Please leave driver settings on default rather than adjust everything to performance. If you do not know how to set it to run at this resolution here is the solution. Go to \Documents and Settings\All Users\[Shared] Documents\Monolith Productions\FEAR and open settings.cfg in a test editor such as Notepad. Change the HXW values to these
"ScreenWidth" "1280"
"ScreenHeight" "1024"
Save and exit. Make sure to set all your image quality settings before you do this tweak because going into some of the menus will reset your resolution to a lower one. Simply set your settings in FEAR, do the .cfg tweak, and then reboot the game. Go to Options, Performance, and TEST. If you dont know how to take a screenshot simply hit the "Print Screen" button, then open up MS Paint and hit Control+V to paste it. Save as, name it and your done...
A64 X000+ @ XGhz
