Jan 10, 2010 #1 Z Zepharus Gawd Joined Sep 6, 2008 Messages 644 Can I use a displayport to DVI active adapter with 3 monitors that have DVI? I know the 5970 has a mini port but if I place the 5870 as the first card in the setup can I use the displayport from that? Thoughts?
Jan 10, 2010 #3 Z Zepharus Gawd Joined Sep 6, 2008 Messages 644 2560? And are you sure i do not need an active adapter? That would be a large cost savings
Jan 10, 2010 #4 A akotlar Guest Zepharus said: 2560? And are you sure i do not need an active adapter? That would be a large cost savings Click to expand... I just edited my post. http://www.hardwarecanucks.com/forum/video-cards/25437-5870-displayport-dvi-non-dell-working.html http://www.widescreengamingforum.com/forum/viewtopic.php?t=16942 For 3 monitors you need an active adapter since the 5870 has only 2 signal drivers.
