I've got two 6950's (clocked to 6970 speeds) running 3 24" monitors (1920x1200) at 6020x1200 resolution after bezel compensation. The MSI Lightning 7970 and the GTX 680 are both looking like good upgrades.
Will the single card Nvidia Surround suffer from the same screen tearing issues as the AMD 6950 had with the mixed Displayport/DVI outputs? Does Nvidia eliminate that by using 2 DVI and the HDMI with an HDMI to DVI adapter? It appears that the HDMI port is a real port on this card and not linked to one of the other DVI ports so this would be the equivalent of 3 DVI ports, right? If so, presumably no screen tearing on the HDMI.
The other issue that AMD suffered from is that of poor drivers. There are reports of the same corrupted cursor problem on the 7970 that plagued my AMD 5850 card. I'm thankful that my 6950 hasn't seen this problem lately but I don't want to see it again with the next card. The latest 12.2-12.3 drivers created issues on my current cards at idle presumably because of a problem in the power-saving mode. All kinds of crossfire driver problems but I don't plan on going down that road again. Assuming that the GTX680 and AMD7970 were close to equal on the hardware side, are the driver issues enough to flip to Nvidia or do they have just as many problems of their own?
I think the 3GB vram of the 7970 makes this card superior but I only have 2GB on the 6950's and haven't noticed that being a limitation yet. If the GTX 680 has 3 usable ports on the reference card rather than having to get a non-reference MSI Lightning for the same feature, it's really tempting to switch to Nvidia -- especially if they end up with superior drivers. I've used AMD exclusively since the Radeon 9700 with the exception of the 8800 series in some Linux boxes -- is the grass any green on the Nvidia side of the fence? Or should I just grab the Lightning when it becomes available?
Does AMD do anything better with eyefinity itself than Nvidia does with NVsurround assuming 3 of the same monitors?
