NickJames
- Apr 28, 2009
I bought a new monitor mount and disconnected everything and reorganized my setup and now suddenly my Eyefinity has stopped working. I did a driver sweep and uninstall and reinstalled 11.7 and still nothing. Here's what happens.
Creating an Eyefinity Group puts all 3 monitors into clone mode. I get no other step to arrange displays. If I go to adjust screen resolution in windows it shows duplicate display on 1 and 3, but if I set resolution to 5760x1080 then eyefinity seems to work except the 3rd monitor is on the wrong side so the displays aren't arranged properly. If I go to desktop management in CCC then it shows all displays as 1, 1, 1. If I disable and then extend manually then the monitors work across all 3 displays, but as soon as I try to create an eyefinity display, it breaks again. What could be wrong?
Setup is
DVI
DVI
Mini DP to DVI
Everything was working fine before I reconnected all my monitors.
*EDIT* Ok seems my 3rd monitor is running in HDTV resolution according to CCC desktop properties.
*EDIT 2* Ok when not having my Mini-DP plugged in, everything works as it should when enabling 2x1 EyeF (Bezel Comp, Arrange etc). Why is plugging in my mini-DP for the 3rd monitor causing issues? It was working fine last week.
Setup is
DVI
DVI
Mini DP to DVI
