Eyefinity Setup... need help.
I am thinking of setting up my first eyefinity 3x1 rig and I have a question.
The video card I am thinking of using is a 6950 2GB. The display outputs are 2x DVI, 1x HDMI and 2x Display port.
What I want to do is, run a 3x1 eyefinity setup off of the 2xDVI and the 1x HDMI. I can't find a definitive answer on the forum or anywhere else on the internet. Seems like there is only certain combos the 3x1 setup works from. of course, if I am buying three new LCD's I need to make sure they have the prop inputs. Thanks.
Here is a link to the card I want....
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102954
Now, the reason I am wanting to do this is mostly for my budget. Newegg has the Hannspree 23" 1080p LED LCD's on sale for 120 shipped, but they only come with VGA and DVI. So of course, I would be able to run two of them right off the DVI port and the other I can use the DVI to HDMI cable I currently own... For a total of three monitors.
Thoughts? Help? Thank you.
Flashing a 6970 BIOS to the 6950 Flex probably won't work correctly. You will have to edit the BIOS.
Your guys rock. Just ordered my 3x 23" LCD's and a single DP to DVI active adapter.
I appreciate the help. Can't wait.
Chris
