- May 22, 2011
Ok am I reading this wrong or do I HAVE to have a monitor that supports Display Port in order to have 3 monitors hooked up to my two crossfire 6850's?
You can use a $30 adapter
http://www.newegg.com/Product/Produ...inidisplay_port_to_dvi-_-15-309-008-_-Product
Just so we're clear, there are two kinds of DisplayPort adapters. Active and Passive. Active adapters are typically more expensive, ranging from $80 - $100. Passive adapters an be found for as little as $20. Here's the difference:
Active adapters have a USB plug for power. They are used for high resolutions, Usually 2560x1600.
Passive adapters are straight pass-through adapters. They work for all resolutions up to 1920x1080, though I used one of these with a Samsung 2343 BWX-1, at a native resolution of 2048x1152. It would flicker on occasion, but a firmware update fixed that.
Hmmmm... Or maybe not solve my problem. So if I wanted to do two 19" monitors 1600x1200 alongside my 29" 1920x1080 then would I have to get the active one?
You're will be fine with the $30 active single-link DVI adaptor that myself and hajalie24 posted a link to. My 6950 xfire setup is using two of the DVI's connectors and one of the displayport connectors /w those adaptors. The three monitors I'm using are 1920x1080 each.
