Golden_Salmon
- Dec 9, 2004
I just pulled the trigger on a new system for ~1k
core i7 920
5850
6gig ddr3
SSD ocz 60gb
Now my monitor setup is as follows:
2x 17" (1280x1024) LCD (VGA only)
1x 22" LCD (1680x1050) LCD (DVI/VGA)
1x 32" LCD TV (DVI/VGA/HDMI)
Now I was thinking about spreading eyefinity across the 2 17s with the 22 in the middle. Problem is, eyefinity requires you to use the displayport (which I will have to use anyway for 4 displays). So this would require me to purchase an active adapter (passive ones will not work for eyefinity). But does an active displayport to VGA adapter even exist (digital -> analog probably won't work, right?) So in this case, I'll need an active displayport to DVI adapter (~100$) to run this.
My biggest question is, when I do this, will I be able to spread eyefinity across just 3 of my monitors? The TV is located a distance away from the rest, so I would need a "dual" monitor setup, with 3 being eyefinity. And will eyefinity even work on the VGA monitors? I assume the displayport one has to be digital, but would normal old VGA LCD monitors work for the other two?
core i7 920
5850
6gig ddr3
SSD ocz 60gb
