The second card is meaningless since you can use the ports on only one card with crossfire -- the only reason to have 2 cards. The best solution is to hook up all 3 monitors to the same type of port on one card so this typically means Displayport. The problem is that the reference cards don't have 3 displayports and that MST 2.0 hubs are vaporware. If you mix the output types, you'll get screen tearing as an artifact.
If you have a reference card, the default option would probably be to use 2 displayports and 1 DVI port. That's what I'm using until I can get the MSI Lightning 7970 card.
MSI Lightning 7970 is the one im waiting on to drop seen it has 4 display port so i be able to hook all my monitors up to the displayports.also any info on if the cards come with the crossfire bridge haven't used ati since the 1950pro.
Crossfire bridge should come with any crossfire capable card. Although I believe XFX leaves them out nowadays. But they will supposedly send you one if you complain.
