Eyefinity question
wikidlad
Finally set up my eyefinity last night (3 x 24") but, how do I make it so its 3 separate screens when using the web or just desktop and then switching it to eyefinity 5760 when gaming?
Was surfing these forums last night and it was stretched across all 3 screens..got neck ache now ;)
Cheers
It's called Hydragrid. Let's you assign apps to certain monitors. Look for it at the AMD Site. Should be part of your driver install package so you can look in there too
Hydravision sucks IMO. In the CCC there are options for setting profiles. So get yourself setup in extended mode, then go in and create a profile and name it something like "desktop use" and save it. Then put yourself into spanned mode and save that profile as "eyefinity mode" or whatever you like. Then you can assign hotkeys to each profile or just right click the tray app to quickly switch between. I really only use spanned (eyefinity) mode for gaming, and the rest of the time I want them to be independent displays.
