eyefinity question
p0b0y
can you use 3 dvi if youre running crossfire 5870's? or do you still have to use teh display port..
1. Crossfire + eyefinity = not working atm
2. Even when it does, you can only use the display outs of the 1st card.
You have to use the DP out for an eyefinity config
you need an active adapter for the third dvi.
crossfire as noted, is due 2010.
