Eyefinity on the cheap
Modder man
Looking for recommendations of cheap monitors that could work well for eyefinity. Looking to try to find three for as close to ~$100ea if possible.
Well with 2x5770's, I wouldn't get monitor bigger than 1440x900 or 1600x900.
I played on 4320x900 on a 4870. Modern games may be out of you reach. Though if you're willing to go for TN panels, you should be able to find cheap monitors. I used cedarpc.com when I was building some of my initial multi-monitor rigs. They have okay deals.
at the top of my sig it says "it died!!!!!!!"....I dont have that hardware anymore. just looking for cheap monitors, I will more likely than not be running a 7970 or two
