Eyefinity Help CCC 13.1
  • Thread starter Deleted member 88227
  • Start date
D
Guest
Hardware:
2500k
6970 + 6990 Trifire
Three 1080P displays
2 are plugged in via Display port using DP to DVI active adapters
1 is plugged in via DVI
Side note: This setup has worked before in the past with an eyefinity setup across three displays. Owner moved and the PC was unused for ~1 year. Finally got it all setup today and now he can't get it to work.
What happens: When he goes to try to setup a 3x1 setup it duplicates the image across all three monitors. When he tries to identify the monitors (by clicking the blue screen) it cuts each monitor in 1/3 of a section. Starting with the first third on the left, then the middle then the right. This is duplicated simultaneously across all three displays.
It's like they're in eyefinity but on a single monitor and the eyefinity setup is duplicated across all three displays. He can't seem to get the eyefinity setup to "extend" across all three.
Any suggestions?
Well he finally figured it out, but he has no idea what he did. Le Sigh.
Although the game he is testing it on (Crysis) wont go full screen. I mean, it's taking up the full screen and spanned across all three displays, but you can still see the window bar across the top with all three icons on the far right, only the "full screen" icon is grayed out. Only minimize and close is available to be clicked.
