Eyefinity displayport no connection fixed
Karandar
From reading various forums there seems to be a lot of people with Display port monitors like me that have had issues.
2 Monitors Connected DVI-DVI on the card, and the 3rd using a mini display port to Display port cable connecting the card to the DP on the monitor. Should work...
Problem is when changing profile from 3 extended monitors to 1 eyefinity 5760x1080, the DP connected monitor would display the error "no signal"
Like many others out there, I had to turn off the monitor and disconnect the power and DP cables, re-power it, then plug in the DP again...not very nice!
I read several cases where using your primary/center monitor with the DP fixed that, no luck. Asus had me try a "reset" of course that didn't work, I had 3 of the same monitor doing the same thing...
AMD has new 11.4 preview drivers. I d/l and installed them, there is now an eyefinity section in the CCC. I deleted my old profiles, and recreated them using the new CCC, and set the hotkeys to alt-F11 & alt F12and can freely change between profiles! no more troubles! yay!
My powered DP to DVI adapter arrives tomorrow...don't need it anymore!
I hope that helps guys and gals
K
just google 11.4 preview and you'll see the link to AMD
one out of 30 times I launch a game or boot up my pc, I'll lose signal to one or both of my Display port displays. They are both connected mini DP (active) to dual link dvi. Unplugging and replugging the mini dp or usb power cables for the adapters fixes the issue. If these drivers will fix those issues too then that would be sweet. Anyone have experience troubleshooting what I'm talking about?
yeah, mine shuts off pretty much every time. i have to alt tab, bring up CCC, click detect displays, then change which monitor is preferred for it to come back on. it always works but it's really annoying
Before this driver update, I had this problem with the DP-dp connection any time I tried to change profiles, it's been great all day! several reboots, multiple times i've changed profiles, so far so good...
K
