I just picked up a second 5850. When I crossfire, my grouping disables and the option to create a group is no longer there. Once I disable crossfire I am able to create a group again. I can only crossfire OR have an eyefinity group. I can't do both. I've tried 9.1, 9.12, 10.1, and 10.2 with the same results. I used Driver Sweeper each time I removed a driver. I've reinstalled windows, just the chipset drivers, and then tried loading 10.2 with the same results. I've switched the monitors from one card to the other with the same results. I ran eyefinity without a problem for 3 months before I picked up the second 5850. My next and final attempt at resolving this is finding my other crossfire bridge and trying that to see if maybe the bridge i'm using is faulty. Once I've tried that and if the results remain the same, I will return the second 5850. I hope it doesn't come down to this.
