Hi folks,
Well I have decided to take the plunge into Eyefinity now that it seems that Crossfire and Eyefinity work well together after the drivers have matured over the last few months.
I am looking at the Acer GD235hz 23.6 inch monitor. I like this monitor because it does 120MHz and a 2MS response time. This should eliminate any ghosting or tearing when I play any FPS game.
So I just want to get my facts str8 before I purchase the equipment. For my card, I am running 2 Sapphire 5870's. Each ther the following on them: 2 DVI-Dual Link, 1 HDMI and 1 Full Size Display Port. The monitors have DVI, HDMI and VGA.
On top of getting the 3 monitors, I need to purchase the Displayport Adapter (Active) to DVI converter. This will allow for full eyefinity correct? Will I be able to run the above monitor @ 120MHz? Or can I just plug in the 3rd monitor into another DVI port on the 2nd ATI card as you can do on Nvidia's setup?
A little confused about this...Please help me clear this up you [H]'ers
Thanks!
Thanks!
