- Feb 1, 2009
Just saw the beta version of ATI Catalyst 10.1 on Guru3d.com
ATI Catalyst 10.1 will have the following
CrossFire X profiles per application will now be in a separate XML file that it will be possible to update independently of the driver itself
ATI CrossFire X with PowerPlay for the Radeon 5×00s: reduced energy consumption of additional cards
AMD Dual Graphics: Possibility of combining performances of the IGP of the RS880 with the forthcoming entry level GPUs from the Cedar and Park ranges.
3D Stereoscopics: Update of the D3D driver so as to allow third party firms such as IZ3D to use their 3D solution with 120 Hz screens. Support for Bit Cauldron glasses.
Eyefinity: Bezel Management
Better GPU acceleration in Windows 7 Video Converter
Support for DisplayPort Audio (already in the 9.12 hotfix)
If laptop manufacturers allow it, possibility of installing the Catalysts on a laptop in Vista and 7
You can download the beta version at Guru3d.com
