Eyefinity Bezel Correction Question and Wierd Side Montitor Image
jahjahwarrior
I've just recently setup my HD5870 with 3 Dell U2311H's. I believe I have setup the eyefinity grouping correctly along with the bezel compensation. I have been testing it with L4D2 and chose the appropriate monitor res with compensation (normally 5760x1080 but with correction 6036x1080).
I have noticed that mainly on the side monitors, things tend to get much huger and what are supposed to be straight lines across the middle to side screens end up being straight if on the top of the screen and then tend to form an angle if on the lower part of the side screen. I will include a link to my Picassa album with pics of what I am talking about.
http://picasaweb.google.com/JahJahWarrior/EyefinitySideMonitorQuestion?feat=directlink
Have you guys experienced this? Is there a way to fix it or is this a tradeoff of Eyefinity?
I belive this is the fish eye effect and you have to make changes to the FOV to fix it. I am not 100% sure but with all the reading I have done I think thats what you mean.
You need to move your bezel over a little more or change the angle your monitors sit next to eachother. And yes there's going to be a fish effect.
I had read something about fisheye. I'll have to see about messing with the game settings. I'm guessing this has to be done for every game?
There's really no way to change the fisheye. Messing with the FOV will only help minimize it at best. Everyonce and awhile you will find a game that will span without the effect, but usually not. Assassins Creed is one I believe.
That's one of the reasons I'll be setting up my surround system in portriat. Those 2311h can be swivel to portrait. Those are the same monitors I bought for my future surround setup. Try it in portrait and let me know how you like it?
What you describe is common to the multimonitor experience. Unfortunately something you can't avoid when you spread the signal across three monotors.
It has nothing to do with bezel correction, its simply a distortion of the EF or surround or whatever you use, but once you start to focus on the center where the game is, you will hardly notice it.
The angle between your displays is huge. Ideally it should be zero but most people have a slight angle on them. Yours is like 30 degrees.
P.S. You should never look directly at the side screens anyway. Put your displays in a line and look at your crosshairs all the time. If you need to look around your environment, use your mouse, not your head. It takes a while to get used to.
