eyefinity and sync polarity
AMoody
Does sync polarity have any effect on eyefinity? I just got my third 30" which is an lp3065 with the other two being dell 3007wfp. I have Nvidia cards right now, and I researched the sync polarity ahead of time but I guess my source was wrong or it changed at some point. the dells are +/+ at 2560x1600 and the HP is +/-
Does eyefinity care at all about this sort of thing? Any issues with setup, extra tearing or anything like that?
This is the first thread ive read of someone asking so it makes me think that eyefinity doesnt care...though I can't be sure.
you will probably not be able to do any bezel compensation with that setup as they have to all be the same monitors to do that. On a seperate note I learned that bezel compensation is not always the way to go. I use it for competitive gaming, but when I play single player stories it becomes a problem. E.G. if you want to read a computer text will be cut off etc..
To answer your question I do not believe that matters at all. Just realize that your probably never gonna be able to utilize bezel compensation.
Sync polarity isn't a big deal with ATI. Bezel compensation is all bound to the EDID - DPI and refresh rates on monitors of the same size (which is pretty much like sync polarity).
eyefinity, in my experience, doesn't care about +/- sync polarity (had a slew of monitors at work to play around with on my HD5770 :)). I have heard surround cares, though.
