Eyefinity and CrossfireX
Exeodus
With the 9.12 Hotfix driver enabling CrossfireX in Eyefinity applications, I was wondering if anyone has the answer to, or some links to answer the following questions.
  • Is the 5970 still the only card to support Eyefinity in CrossfireX currently?
  • Has anyone tried Eyefinity while running a 5850, 5870, 5770, or 5750 in CrossfireX?
  • With two cards in CrossfireX, are you limited to three ports (2 DVI, 1DP) or six ports (three from each card)
I am sure I am not the only one with these questions, so hopefully we can gather some good information here.
Thanks in advance.
Thanks in advance.
Take a look at Kyle's response... Its a matter of what games they tested and what games you plan to play... Support it seems is still lacking..
http://www.hardforum.com/showthread.php?t=1483592&page=2
"I am currently NOT suggesting CF and Eyefinity yet. There is more work to be done before you rely on that as your primary gaming system and I think the 5970 numbers point that out."
Yep.. it's not fully baked yet... when it is though I will be shopping for another 5870 ;)
I think you just enable/disable your display group in ccc... didn't need a reboot in Kyle's video.
