Eyefinity Adapter Help
Kenjiwing
Quick question.
My scenario is.. I have 3 monitors I would like to do over eyefinity.
a 3007wfp-hc, and 2 dell 2007fps... I also have a 5870.
I would like to set these up with eyefinity.. the 2007fps only have DVI and VGA.. and the 3007 only has DVI and the 5870 only have 2 dvi and 1 hdmi and 1 display port..
What do I need connector wise to be able to eyefinity these 3 monitors?
One has to be a Display port so you will need an Active Display Port adapter. They should all be plugged in via DVI, as the adapter is DP to DVI.
Amazon DPA $95
or
Dell DPA 99$
All 3 monitors have to have the same resolution to run eyefinity so your set up wouldn't work.
