Atherton213
- Dec 21, 2004
OK... so i plan on going 3x1 eyefinity in the near future... just not sure which card to get
i know that for the 3x1 cards you need to get the DP active adapter (which is ~$100)...
do you need to get one for the 3x2 cards? i see they come with a bunch of little non active adapters in the box... and the cards seem to run $100 more than the 3x1 cards... if thats the case that you dont need one i would rather spend the $100 and get a slight performance boost
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125322&cm_re=5870-_-14-125-322-_-Product
^ just an example to show the little adapters it comes with... there is 2 dvi, 1 hdmi, and 2 DP looks like
i know the 3's you cant use the DVI and HDMI its one or the other... just curious to find out if thats the case with the 6's
