Eyefinity 3x1 Portrait Issues
AEracer7
Hello, I recently finished a monitor mount allowing my monitors to rotate to portrait and I was really excited to use eyefinity in portrait mode, but I am unable to do so. I have tried the guides AMD has published and quite a bit of Google searching with no results.
If anyone could help me or point me to a guide or tell me how to create a portrait eyefinity group I would greatly appreciate it.
Also I have an AMD OEM reference 6950hd and 2 monitors are connected with dvi and the third is via an active display port to dvi adapter.
Thanks in advance!
Dumb question, but did you set your monitors in portrait mode before trying to make the Eyefinity group?
What process did you use to attempt to create Eyefinity portrait and what was the result?
I run Eyefinity portrait and had no issues setting it up.
Only enable one monitor.
Put it in portrait mode
Clone the two remaining monitors
Setup eyefinity as a 3x1
The key is to make sure that all the monitors are cloned and in portrait mode before creating the eyefinity group.
Somehow last night after posting this I accidentally stumbled upon it and got it into 3x1 portrait but I still want to be able to replicate it.
I do believe it was the cloning part I was missing. Because I had all 3 in portrait mode then used create eyefinity group and the picture on CCC was of a 3x1 portrait but it would always go 3x1 or 1x3 landscape.
I will try the steps mentioned above later when I get back home. Thank you for your help.
