So I had the GPU-180-L06 on. The little heatsinks were kind of sad to look at, and when things got intense in 3D, they would get too hot to touch.
ATiTool determined my max OC to be 425/510 up from the stock 400/490. Needless to say...crappy.
So, I saw the fancy schmancy (ridiculously expensive) EXOS GPU waterblock out for the ATi x800 line. $115. The claim to fame is that it cools both sides of the card at the same time...all memory surfaces and the core with direct water cooling. Sounds good huh?
Well, I installed it carefully, applying new thermal paste, following the instructions, ensuring the best possible surface contact.
Good news is, the installation went flawlessly (despite being a mess draining the EXOS and removing the old GPU waterblock). Bad news is, it was basically pointless.
New ATiTool overclock: 430/520.
$115....for 5 mhz core and 10 Mhz memory. What a giant waste of money.
So, my next instinct was the bump up the voltage on the card like I did back in the day on my 9700 Pro. Then I realize I don't see any place to do that in my BIOS. Am I nuts, or is there no direct control over the PCIx voltage?
Current rig:
Athlon 64 3500+ @ 2.5Ghz
1GB (2x512) OCZ Gold VX DDR500 2-2-2-5
ATi Radeon x800 XL 256 @ 430/520
DFI Lanparty Ultra-D w/ 3-31 BIOS
Koolance EXOS I w/ CPU-H06 and VID-AT1-V06 waterblocks
Current rig:
