Hi,
My desktop bit the bullet and I have an IDE drive in it that has a bunch of music on it. It also has a 250G SATA drive which I want to buy an enclosure for. Problem is while the SATA has very little data on it, it is larger and I want to use it for portable storage, while the data I want is on the IDE. What is the easiest or cheapest way to get the data from the IDE onto my laptop? I obviously don't want to buy a full enclosure. Can you buy just the USB hookup? Where would I get it from? Thanks,
John
John
