I have an Antec Sonata II case for my C2D system. I am running a DS3 mobo with E6600 and Scythe Ninja Rev. B (removed part of bracket to clear capacitors, oriented so lower heatsink fins run front to back, fan mounted towards front to blow hot air to rear exhaust fan). I also have a 120mm Antec tri-cool fan mounted in the front position behind the hard drive cage. I am not using the cpu cooling duct that came with the case. I have noticed while overclocking that if I remove the external 3.5" bay covers and the unused upper 5.25" bay cover that I get better cooling since there is more open area for intake air. I was looking around for something I could use for grilles for these two areas, and came across two products I want to see if anyone has experience with: Evercool 5.25" Drive Bay Air Blower Fan and Ultra 5.25" Bay Freezer. The Evercool blower is designed to be used to draw hot air out of the case, but I was thinking I could mount it backwards inside the case and attach a rectangular duct to the 5.25" bay with a grille/filter over it and really get more air into the case (up to 100 cfm if I can stand the noise). I was thinking similar thoughts about the Ultra freezer -- modifying it so both fans draw intake air (not one intake one exhaust as stock). Any thoughts or suggestions?
Also, I modified the 3.5" slide-in drive trays to accept bottom-mount HDD coolers and would like to post a short DIY article with pics but can't seem to attach photos here. How can I do this?
