Extra connections on monitors
Do you use the extra connections on your monitor?
  • Yes
    Votes: 11 78.6%
  • No
    Votes: 3 21.4%
  • Total voters
    14
theDreamer
I always read about monitors adding USB connections, card readers, etc., but what I am wondering if how many people use these connections. Also are they any good? Do the USB connections have problems at all or the card reader slots?
IMO the way you formulated your question is not correct.
Everything more than a single DVI is an extra connection.
If you mean USB - ask about USB.
1. I never use USB - I don't like extra cords, my PC is very convenient with many USBs.
2. Never use analog connectors for video (Component, Composite, S-Video) - they are useless.
3. I use extra DVI - it's necessary for Full HD video.
How shall I vote?
How shall I vote?
Ummm...the question is do you use anything besides just your video connection, pretty simple and straight forward, hence extra connections.
I use the usb ports on some of my monitors some times. Other than that, just vga on my crt's and just the dvi port on my lcd's.
I often work on others' computers, so the VGA input on my display gets used quite a bit. If it had USB port, I'd probably use those since the computer itself in low to the floor and is a pain to reach. Card readers and speakers I wouldn't use though.
I have a Dell 2407WFP A03. I use the card reader to backup financial data a lot. I use the usb port for the keyboard. I use both the DVI and VGA ports. They work quite nicely. I could get along without the usb stuff; I have before.
Dave
Dell 2407wfp A04 here,
I use the usb ports on the back for my webcam and wireless-mouse dongle. I use the side ports occasionally for thumb drives.
If I had an xbox or ps3, I'd definitely use the component inputs to hook them up.
I also use the power connector, just because I feel like it.
