I am looking to replace my FIOS modem / Ruter with the Ubiquity lite.
Question tho, currently it's connected via coax, that Verizon ran up the outside of my 2 story house and then through the attic to my office.
I need to replace that cable with ethernet, but the question is do I go through the wall into the garage, and then try to fish ethernet through the house (office is opposite side of house, 1 floor up), or run a cable from the ONT tacked to the coax line up the side, then into the attic.
The line will probably only be outside for 15 feet or so before entering the attic.
I've read about the direct burial ethernet lines, and that's the way I'd go.
The main question is lightning. For such a short run, how likely will it be to pickup a charge from storms?
I REALLY don't want to run a line inside, as this will be an absolute pain, just wondering if other people have done something similar and have feedback?
Thanks
Brad
Thanks
Brad
