First question: The MCR-320 radiator is way too long to fit mounted on the back of the P150/SOLO case with a radbox. So are there any other options? Are there any good/silent radiator cases I could use to mount it on top of the case?
Second question: Even if I just go with the smaller MCR-220, the radiator hangs down over the entire right half of all the PCI openings (MCR-220 Mounted w/ Radbox, Back of Antec Solo) and it doesn't look like even with the radbox as a spacer there would be enough space for the monitor cables to the 8800GTS card I'm putting in. Does anyone have an experience externally mounting these 2x120mm radiators and how much space is left for cable access to the PCI/PCI-e slots?
