Carlosinfl
Loves the juice
- Sep 25, 2002
I just ordered a Lian Li PC-9F case and can't decide if I want to mount a single 120mm or 140mm radiator internally or externally. The case has a top mount 140mm exhaust fan hole which I can internally mount the radiator to or I could externally mount a single 120mm radiator to the back of the case. If I do externally mount the radiator in the rear of the case, is there a mounting kit that allows me to mount the radiator to rear 120mm exhaust fan setup? I would think there's a kit with spacers, brackets, and hardware to externally rear mount a single 120mm radiator.
Anyone know?
Anyone know?
