externally mounted black ice pro II
Hi ive been searching but not finding. Im building a new watercooling setup based on a coolermaster mystique case because of this cases small size its impossible to mount an internal radiator. So I want to mount it externally to the back of the case but i have been unable to find any kits or anything to do this. Also does anyone know the difference of the black ice pro II and black ice pro II X-Flow (they both cost about the same), and is a double 120mm rad good enough for say a q6600 and a pair of 8800gts's?
PS Im attaching a pic of an externally mounted koolance radiator which is basically how i would like to mount the black ice...though the koolance is WAAY too expensive.
Firstoff... NO! A double rad is NOT enough for a quad core and 2 8800s... You need at least a triple. Preferably a triple with another 120mm somewhere. A double radiator would result in water temperatures about 15c over ambient, which would put your CPU temps about 10c higher than if you had a triple radiator.
Next, the Xflow has input and output barbs on opposite ends, where the non-Xflow has both barbs on 1 end.
Last, you can mount any radiator on the back of your case using a Swiftech Radbox.
thank you this answered all my questions :)
I'd also recommend picking a thicker radiator than a BIP unless you need to be running incredibly low CFM fans. The reason why a triple (with possibly another 120) radiator is recommend is that larger radiators have more cooling capacity (effectively a lower C/W), so they can keep the water temperature from rising as much as a smaller radiator. Black Ice Pros simply aren't large enough to cool that much heat without temperatures climbing so much - Swiftech's MCR series is thicker and has a higher performing design, so I'd recommend raising your budget for an MCR320 (3x120).
more good advice!.. Ive actually decided not to cool the video cards im just going to water cool the cpu and north bridge, according to others a dual is plenty for this, do you agree? Also Im going to get a swiftech rad like you said because A: its cheaper B: everyone seems to say the same thing you did...they're better.
no need to wc your chipset really ...
mcr 220 and bip 120.2 are about the same size .
everyone will say the mcr220 is better but i have tried both and couldn't see no real difference but mcr 220 to be on the safe side .
bix 120.2 is much thicker then the bip 120.2 and the mcr220 . if you plan running high cfm fans then the bix is probly a better choice ...imo
nah the chipset is a must. Not on some boards but on some (like mine) they get way to hot (78c-82c at full load) and its causes the system to crash, its fanless heatsink design and it sucks
